Old 01-16-2015, 07:05 PM
paul cass paul cass is offline
Hey guys. I haven't had time to write a follow up to this story. It is quite lengthy but I will try to print it in the next week or so. I will say this. If you check around you shoud be able to find an ASE Master Tech that will work with you. Usually they work at a garage not at a dealer. After doing some research I found that there were a couple here in Corpus Christi. Through a friend I found one that was not anal and did the inspection for $70. Unfortunatley the State does not suggest a set fee so it is up to the Tech as to how much he wants to charge.
