  #36 (permalink)
Old 01-17-2015, 03:07 AM
1 TUF AC's Avatar
1 TUF AC 1 TUF AC is offline
Cobra Make, Engine: Harrison, LS1 stack injection
Originally Posted by Rog246 View Post
Mate I had the same trouble when I was putting mine together. I swapped the 1/2 shafts from side to side !! They are not the same length either side.
I felt bit of a dill to be honest but fitted like a greasy stick in pig's bum when I swapped 'em over !!
I ended up getting them both in but the right hand side is very tight with only 15mm play. I definitely put them the right way. I think there's a possibility that the wrecker Gave me the wrong Axle. Or this conversion doesn't work on a r32 rear ends. Only r33 rear ends. Might have to get the axles shortened.
