Old 01-17-2015, 09:18 PM
Mongoose930's Avatar
Mongoose930 Mongoose930 is offline
Cobra Make, Engine: Hi-Tech
Hi Bill,
You probably saw my engine while you were there. Sounds like we will have similar engines with the difference being that I have a cast iron center oiler. It is a stroker motor with a scat crank, H-Beam rods, 482 cubic inches, Diamond 10.5:1 pistons, Felony heads and a Blue Thunder manifold. I did handcuff Barry a bit with my Lemans carb. bowls and dual point distributor to keep it looking period correct but it was still at 550 HP and 560 LB torque with a roller cam. I have attached a couple of pictures. Good luck with your build - Barry really knows his stuff.
PS - Barry will be machining off the Edelbrock logo from the water pump.
