Old 01-18-2015, 05:33 AM
DanEC's Avatar
DanEC DanEC is offline
Originally Posted by joyridin' View Post
I powder coated my rotors and calipers. I taped off the surface where the pad hits the rotor to avoid having to clean it later, but no problems with melting powder coat at all.
My sidepipes are also powder coated with high temp black powder. No problems whatsoever.
The caution I remember on aluminum wheels had to do with affecting their physical strength properties from ovens that were set too high - again not sure how valid it is. Wouldn't be an issue with steel or gray iron parts.
Didn't realize they had a powder coating now that would stand up to header heat.
Edit: easier to Google than speculate.
Cautions: http://www.uniquefinish.com/coastingwheelsafely.htm
ERA 782 Running
