Thread: Blown LS3 Build
Old 01-20-2015, 02:27 AM
tkrupinski tkrupinski is offline
Cobra Make, Engine: Shell Valley Supercharged LS3. Factory Five MarkII Dart Blocked 410 Stroker.
This was the engine after cam springs and supercharger. In back background is the TR6060 trtransmission out of the 2012 camaro. You can see the low mount alternator, it would not clear the frame and had to be moved to the top of the engine. If I didn't install the supercharger I could have just purchased a new upper bracket. None of the off the shelf brackets will fit due to the throttle body being upside down on the supercharger. I had to make a custom bracket for it and also move the idler pulleys to the bottom. All worked out and the same drive belt was able to be used.
