Old 01-25-2015, 01:19 PM
DanEC's Avatar
DanEC DanEC is offline
With a 12.64 battery voltage, parking lights on, key off:
Driver side tail light 12.24 volts
Pass side tail light 12.21 volts.
Interestingly I was picking up .2 volts at the turn signal lead at the lights.
How am I supposed to check voltage drop across the trailer relay? When flashing the voltage is jumping up and down of course. I thought I might get something from the red wire on the car side from the brake switch by pushing on the brake pedal but it was only a few volts. I also noticed the same .2 volts across the relay with the parking lights turned on.
ERA 782 Running
