Old 01-26-2015, 12:32 PM
patrickt patrickt is offline
Now, assuming, with Fuse #6 out of the car, and both of the two little fast blow fuses installed properly, the LED turn signal still flashes all four corners regardless of whether you're signalling left or right, then I want you to remove ONE of the fast blow fuses and try the turn signals, in both directions, and report the results.
