Old 01-27-2015, 04:53 AM
CobraDan's Avatar
CobraDan CobraDan is offline
Originally Posted by LMH View Post
Maybe slightly off the subject but can an aluminum body be made using a donor fiberglass body as a buck? Wouldn't the AL body be too big?
Answer:
Yes, it will be too big and far off. You can’t use a fiberglass body as a buck. But you can make a heavy buck using the fiberglass body as a reference. The first problems you will encounter are the headlight rings. They will not match the chrome rings from the head lights. Just an example. It will also affect all the gaps and width of the car.
Dan Wulff
