Old 01-27-2015, 11:36 AM
patrickt patrickt is offline
Dan, you might want to try this: Put your old incandescent bulbs in that you were reasonably happy with. Pull your Fuse #6 and put a VOM on the driver's side of the fuse receptacle. Then turn your key on and put your turn signals on. See how much, if any, your VOM indicates. Then do the same with the LEDs and compare.
