Old 02-01-2015, 03:05 PM
Large Arbor Large Arbor is offline
Cobra Make, Engine: ERA 714
I would pull the starter and look at the gear teeth. Make sure it is fully engaging on the flywheel. I lost a ring gear due to the wrong starter only engaging 25%. I would also rotate the engine with the plugs out while you look at the flywheel teeth. I would also check the starter bolts to be sure they are tight.
Phil
