Old 02-02-2015, 09:45 AM
DanEC's Avatar
DanEC DanEC is offline
Originally Posted by kevins2 View Post
Hi Dan,
Since you have both the Pilots and SuperBrights it would be good to know which is brighter, if you can see a difference.
Kevin
Hey Kevin - fooled around with the SuperbrightLEDs again and installed one of them and one of the Pilot bulbs for comparison - had a difficult time doing so because the Superbrights didn't want to light on the parking light circuit.
I took a picture I could post but to be honest I couldn't perceive any overall difference in illumination. I could see through the lense that the Superbright bulb had a larger stack of leds lite up - and the Pilot a smaller group - but the overall effect looked to be the same. couldn't really compare the flasher circuit.
However, I can't get the SuperbrightLEDs to light up on the parking light circuit. I had to fool it by un-seating it and at one point it would light up sitting loose in the socket. I think it was on the parking light circuit but not 100% sure. There is power to the bulb socket as confirmed by my VOM - but nothing lights up when the bulb is seated in place. I even tried reversing the leads to the socket but still nothing. Turn the parking lights off and the turn signals on and they flash completely normal. However, when I disconnected the red parking light circuit leads to the bulb holders, I had power on the bulb side (red wire socket) flashing with the flashers - just like the Pilots. It was flashing over 8 volts peak. Checked the red wire leads and they were dead (as they should be with parking lights turned off).
So, I don't know - the Superbrights seem to work fine in my GTX - go figure. Short of calling Ghost Busters I think I'm stuck with 1157/2357 bulbs.
ERA 782 Running
