Thread: 460 usability?
  #27 (permalink)
Old 02-02-2015, 02:38 PM
cycleguy55's Avatar
Originally Posted by D-CEL View Post
Brian,
Quoted? LOL, who knew?
I cant say exactly how much just the pan holds, but I would guess its 10+ with my dip stick marking. A full load at a change is 15qts.
Yes I would use and recommend that pan again.
Also important is that you address the oil return from the heads.
Jason
I've only had the car since mid-July, and most of the next 3 months was getting safety approval. I've had the valve covers off once, but failed to check the oil returns to see if that work was done when they milled the rocker stands and installed positive lock seals.
I'll need to add that to my 'to do' list, along with all the other stuff that needs doing, modifying, replacing, upgrading, etc.
Brian
