Old 02-03-2015, 04:11 AM
blykins blykins is offline
You can only have one input shaft length if you're using it with an aluminum bellhousing. It would be the standard 7"-ish long input shaft.
The shifter positions basically boil down to this:
*The rear socket position (standard shifter position) can be used as is, or you can flip the shifter around 180°
*The middle socket requires a new shifter.
*The front socket requires a new shifter.
All-in-all, if you're not having any issues with your driveshaft or u-joint stir, then I would just put it back together the way it is and snag an RM-6060 to keep your feet intact.
Lykins Motorsports, LLC
www.lykinsmotorsports.com
www.customfordcams.com
brent@lykinsmotorsports.com
