Thread: 445 Build
Old 02-04-2015, 07:26 AM
blykins blykins is offline
The different pins are not because of the thrust plate, they are because of the different eccentrics out there....one piece or two piece. You need to figure out which timing set you're using and what eccentric it will accommodate and go from there.
Next time you get a stuck pin, clamp the pin in a vice, then tap on the nose of the cam with a brass drift.
A mechanical pump works just fine.
Lykins Motorsports, LLC
www.lykinsmotorsports.com
www.customfordcams.com
brent@lykinsmotorsports.com
