Old 02-06-2015, 02:51 PM
vatdevil vatdevil is offline
Cobra Make, Engine: Superformance #522
Originally Posted by Detroit Bill View Post
I have read all kinds of things about them including:
Heat cycling out and becoming hard
They have to heat up to grip
Throwing/picking up everything on the road
How does that work on the street? I am looking for something that hold the power as much as possible.
I actually am set up to get the NT01's but I have a couple weeks to make up my mind.
There's a little drop off in grip after many cycles, but not noticeable for street use. Compound is road race, gets real grippy around 160F, but traction when cold is still excellent. As a comparison, from cold to hot they will drop less than a second on Autocross runs. Yes, they will sling small stones on street. Get em real hot and you will clean the road. They're fine in rain when new, just don't plow thru standing water. Once you wear the tread off and only the two circumferential grooves are left, advoid the rain. These aren't drag tires (stiff sidewall) so hard launches can produce wheelhop if you're on a grippy surface. They corner unbelievably....
