Old 02-06-2015, 02:14 PM
Detroit Bill Detroit Bill is offline
Cobra Make, Engine: Superformance, Survival Motorsports aluminum FE 482
Originally Posted by vatdevil View Post
There's a little drop off in grip after many cycles, but not noticeable for street use. Compound is road race, gets real grippy around 160F, but traction when cold is still excellent. As a comparison, from cold to hot they will drop less than a second on Autocross runs. Yes, they will sling small stones on street. Get em real hot and you will clean the road. They're fine in rain when new, just don't plow thru standing water. Once you wear the tread off and only the two circumferential grooves are left, advoid the rain. These aren't drag tires (stiff sidewall) so hard launches can produce wheelhop if you're on a grippy surface. They corner unbelievably....
I believe the tire choice is going to make my head explode. This car will not see the rain, at least by choice anyway. I want something with big grip to handle the power I am planning on (as much as it can be handled). And I want it to handle well and predictably. I am not so concerned with wear I just want the car to be stuck to the road.
I am somewhere between the Nitto NT01, NT05 and Michelin PS2's. There's a wide spread.
Bill
