Old 04-20-2002, 05:20 PM
carlo carlo is offline
dcappo, square the front and back of your engine to the frame(center the drivetrain),if you have adjustable 4 link,tweak the rear end to square on the frame also,if you don't, proceed to take a reading from the differential yoke with a angle finder or a machinist square.If your 4 link is fixed (no adjustment) then you will be raising or lowering your transmission to maintain a PARALELL LINE with the rear end,allowing 1 to 1 1/2 degree - on the only variable you have. Do not think it should be off set as in my case or Campys, the straighter the better,but maintain the paralell center lines,our cars are designed offset (left to right) but yours is the PREFERED DESIGN.
carlo
