Old 02-08-2015, 05:48 AM
DanEC's Avatar
DanEC DanEC is offline
Other than carefully setting the lifter preload to .035 to .040 roughly (cold) I haven't really dug into the motor. Trusting Keith and his guys to have put it all together right. The heads are 61 castings and he worked them over top to bottom so I'm sure the exhaust side was checked and lightly milled as necessry.
I can't really do much to the sealing surfaces at this point. I have full length undercar exhaust and removal starts with the tail pipes and it's a ***** to get the whole thing removed - just reinstalled it. The headers pipes are all individual - no common flange. I checked them out before installing and they looked great - flat. Motor is in the car - clearance is tight - not planning to remove anytime soon. Probably just install the Fel Pro 1442 gaskets and drive it for awhile and see what happens.
I would have tried the Remflex but it's virtually impossible to order gaskets for the early LR heads on line because the gasket producers don't differentiate between the high port and the low port heads. I pretty much have to order by picture, judging the distance between the upper bolt hole and the top of the port opening. As a result I have a new, un-used set of SCE low port copper gaskets if anyone is interested.
ERA 782 Running
