Old 02-11-2015, 11:23 PM
Ace23 Ace23 is offline
Cobra Make, Engine: SPF#1867 , KC427
Originally Posted by olddog View Post
From my perspective a high performance engine verses a factory family car engine is a double edged sword, from a reliability point of view. Typically a good builder improves the oiling system and puts in more durable parts (likely to balance it better too). So the rotating assembly should be much stronger to take the intended abuse.
On the other hand, to get more power, more radical cams, with higher valve lift, are used. Then stronger springs are needed. I have seen radical racing setups that they loosen the rockers in the off season or just change the springs out each season. Letting an engine sit in one spot over the winter leaves a couple valves open. That is a long time to keep a spring compressed. From my perspective the springs are taking a beating over time, not miles. Now that assumes it is not getting revved up until the springs are dancing violently, which can take its toll in minutes.
So, I generally worry about valve train stuff the most. The more radical, the more concern. That assumes that everything else was done well and there are no issues with fuel washing down cylinders.
Thanks for the opinion. I'm not sure what cam this motor has in it but I believe it's a hydraulic comp that is probably not to far off from what normally goes in this Keith Craft setup. I believe the current owner has put about 8k trouble free miles since he's owned it and it's a street setup. Obviously has some cam in it but nothing to radical. I guess I should get hooked up with someone that can help me learn a bit about maintaining a old school motor. I don't want to get much more involved than oils changes, performing a leak down, plugs ect. I want to spend my time driving not wrenching. Car is definitely sorted and I know you will be turning a wrench here and there that's just the norm. I guess like anything regularly cranking it wouldn't be a bad idea either. I'm from the younger demographic who has only had fuel injection vehicles.
