  #155 (permalink)
Old 02-13-2015, 02:41 PM
DanEC's Avatar
DanEC DanEC is offline
Well - where do you suggest I start? Car runs fine until turn signal turned on and then fuse 4 blows. Fast blow fuses at trailer relay are fine.
There is a circuit from the fuse to the flasher unit and red-charging light. Also a lead from the voltage regulator, a lead from fuse 5 and fuse 4 appears to be linked to fuse 3. Haven't checked to sere if it blows when signaling in both directions - running low on fuses.
I'm probably not going to have much chance to mess with it for a couple days.
ERA 782 Running
