02-13-2015, 04:30 PM
Cobra Make, Engine: Superformance, Survival Motorsports aluminum FE 482
Originally Posted by RodKnock
I'm assuming the aluminum intake is there already, in the first place. Not many folks running a cast iron intakes anymore, unless it's a restoration of an original.
As I said, the weight savings is a rounding error. A Kirkham weighs around 2,100 lbs. An SPF weighs around 2,600 lbs. That's 500 lbs savings right there. Of course, for a higher price. There are lots of places to save weight, but the alloy heads should be purchased for flow, not weight savings.
Losing 20 lbs around the middle would do the same thing and you get the benefit of potentially living longer. Alloy heads can't do that.
So for you 40 pounds is not a lot. I don't think the OP is shopping Kirkhams. How else do you save 40 pounds on a Superformance? Yea if you are carrying extra weight lose it I get that.
Bill
