Old 02-16-2015, 12:08 PM
DanEC's Avatar
DanEC DanEC is offline
I guess you don't want to just pull your turn signal off the steering column and test it off the column, do you?
I think first I'm going to disconnect the wire from the dimmer relay and run the turn signals in both directions and see if I pick up some voltage on it when I turn the left signal on. I'll also check if the other side feeds power through the relay to the switch even when the HLs are off. At leas then I will pretty much understand how everything works.
Probably at that point I'm going to pull the wheel and the switch out to test.
Stay tuned.
ERA 782 Running
