Thread: Pre-ignition
Old 02-18-2015, 05:53 PM
Dimis's Avatar
Dimis Dimis is offline
You suggest that this happens in frequently... just a slightly different line of thought if I may... I'm no expert.
Have you noticed any common denominator?
Like after a long spirited run where your engine is running a little hotter than normal?
Any chance your carb is oversupplying fuel ie: high fuel pressure or high float at this point (feeding the engine more fuel) causing the engine to run-on after you kill the electrics?
If so, its possible that this run-on may be preventing your engine from cylinder wash.
In any case, as others have mentioned, Lippy's method is a simple fix.
