Thread: Carb to EFI
Old 02-21-2015, 01:21 PM
olddog olddog is offline
Originally Posted by lippy View Post
If you have a big cam with lots of overlap, you won't be able to run EFI in closed loop mode because the oxygen sensor can't get a good reading with significant unburnt fuel passing through the engine at lower RPM.
It think it is more the oxygen, causing a false lean reading. I have not done this, but the tuners tell me to target a lean AFR at idle to get the desired actual AFR.
