Old 02-24-2015, 09:51 PM
750hp's Avatar
750hp 750hp is offline
The Arntz is running the smaller and lighter 153 tooth flywheel and bellhousing size. It's a billet alloy flywheel, which would be a laugh behind a tough big block, but the starter motor might be a bit unhappy if you tried to get the 153 tooth combo to spin a big cubes/big compression motor.
Of course, I only assume that any replacement engine will have big cubes and big compression. Oh, and about .770" lift on the camshaft should be just about right as well...
Craig
