Thread: Rear Toe
Old 02-25-2015, 02:53 AM
Default There is a grease fitting
Patrickt Pat I have contemp rear housing on my jag setup. There is a grease fitting to lube these bearing for the outter assembly. I would think the same could be done for the OEM housings. I run Lucas high temp red grease. I apply it the same as doing the u joints about 2 -3 shots or if the pressure builds on the grease gun. it's a feel. I don't see why you could drill and tap a grease fitting into each hub. I would have to look in the shed at the stock outter housings to see if this is possible. The Contemp housing have no vent hole I could see. Rick L.
