Thread: Rear Toe
Old 02-25-2015, 02:00 PM
strictlypersonl strictlypersonl is offline
Typically, the inner brackets are shimmed out from the differential to give the proper toe value. On the stock Jaguar setup with subframe, the inner pivot axis is fixed by the holes in the subframe itself, and the space between the brackets and the differential casing is filled with appropriate shims. The geometry is determined by the subframe, not the differential casting.
