Thread: Rear Toe
Old 02-25-2015, 02:08 PM
redmt redmt is offline
Originally Posted by strictlypersonl View Post
Typically, the inner brackets are shimmed out from the differential to give the proper toe value. On the stock Jaguar setup with subframe, the inner pivot axis is fixed by the holes in the subframe itself, and the space between the brackets and the differential casing is filled with appropriate shims. The geometry is determined by the subframe, not the differential casting.
That is sort of what I figured,,,, I've never seen one or noticed one with shims. I suppose it is possible that they were never adjusted on other cars and the builder took it for granted that it was correct. Me,,,,, I check and double check everything as I go and then check and double check each assy. and what it's relationship is on everything else. I've worked on a few other cars and the suspension geometry was a joke. The hack that set up the suspension on Ron Wideners coupe didn't even have the A-arms in the same plane yet nobody even noticed.
Thanks for the input. It verify's what I finally figured out. On the good side, I now know that all the components are true and square.
