Old 04-21-2002, 06:01 PM
DAVID GAGNARD's Avatar
Ken;
I have a 351-W in a 65 Mustang,same engine different car but the engine doesn't have to know that.....my alternator is on the upper passenger side.....the top bolt is large and has the aluminum spacer and bolts into the head or rather a bracket on the head if the head does not have the correct hole (most do).This bolt goes thru the top hole on the alternator...The lower bracket is a curved shaped half moon looking thing that bolts to one of the water pump bolts and the alternator then slides on the long slot in the bracket.Very simple and mine came off a 70's Ford p/u with a 302 and no power assc...I have an extra lower bracket or two if you nedd one just holler and I be glad to send you one.....
David
DAVID GAGNARD
