Thread: detonation
Old 04-21-2002, 07:08 PM
Richard Hudgins's Avatar
Richard Hudgins Richard Hudgins is offline
Cobra Make, Engine: Porsche 928 S4
two89w,
there are a couple of things to look at here.
1. As you are using webers, look to the emulsion tubes and air correction and main jets in number four.
2. If one cylinder is detonating and no others I would look to oiling in that cylinder. At 600 miles, the rings are just starting to seat. If you have a bit of oiling (as the black plug indicates, the oil will reduce the octane rating and cause detonation)
3. Timing. This is not your problem. If you were advanced too much, you would see indication of detonation in all cylinders. (ceramic boiling on the plugs etc.) Note: Black in Black. retarded is later in the stroke sequence, advanced is earlier.
4. Fuel flow. Since you have a 347, I will assume that you have 450 hp. At .45 lbs per hour per horsepower, you will need a fuel flow of 450hp X.45 lbs per hour = 202.5 lbs per hour fuel needed. 202.5 lbs divided by 7 lbs per gallon = 28.92 gallons per hour usage. Therefore any normal pump will cover your needs.
If it were me, I would look to oiling as the problem. This is the most common cause of single cylinder detonation.
As an aside, I am quite surprised that the dyno operator did not notice something amiss during the run. When detonation occurs, BMFC goes off the map. Right now. No waiting. Exhaust temp goes goofy. The dyno response goes really woogy as soon as detonation starts. Were they even looking at the instrumentation? I would be really pissed if a dyno guy ran the motor long enough to hurt a piston. For Christ sakes, that is what dyno are for. To find the problems and tune the motor. Not turn it into junk.
Sorry if this seems a bit harsh, but I have stood at the console for many hours and have screwed up enough development motors to know how not to make one trash. Particularly a normal motor such as yours.
Best regards,
Richard Hudgins
