Thread: Cammer parts.
  #191 (permalink)
Old 02-28-2015, 11:53 AM
Dimis's Avatar
Dimis Dimis is offline
Ummm. I think you blokes HAVE missed something.
Or at least are reading things quite differently to me.
Originally Posted by damage View Post
This is the email from my engineer here in Australia.
"Sent: Tuesday, 24 February 2015 2:38 PM
To: David Trask
Subject: HEADS
Hello David,
Attached are photos of the heads with crack test die on them.
You can see on the welded exhaust port head that 3 of the exhaust ports have cracks(one with 2 cracks).
We pushed a scribe through on of the exhaust port walls(at the most 1mm thick).
On the back of the heads in near the rocker gear you can see that there are cracks coming from where the plugs are.
You can see, if you look carefully that one of the plug areas has been welded and polished off and still looks suspect(so they are aware of the problems).
The person who supplied the heads SHOULD 100% supply you with a new set of heads to replace this pair.(FREE OF CHARGE)
Not being rude to you but these heads are **** and have been patched up and unloaded onto you.
The people who did them would be fully aware of how bad they are!
They have been ported too much to suit the casting and have ended up thin.(being thin and having really bad porosity is not good either for down the track).
They need to have some heads ported .040” -.060” per side undersize or get better casting thickness.
Do you want to have a conversation with them before we continue?
The next step for us with the heads is to pressure test them to see if they are going to leak anywhere else apart from the cracks.(eg porosity holes)
Phil "
I have removed his company details deliberately as there is no need to involve him in this dispute.
This is my email to Keith Craft where I politely gave them a piece of my mind.
On Tuesday, February 24, 2015 1:00 AM, David Trask <david@trask> wrote:
"Lance,
Once again no one has responded to me since our last email exchange on 19 February. I’m guessing this was deliberate so I didn’t show up at your workshop while I was in the US.
Please see the email below from the guy here in Australia who is helping me with all the crack testing and machine work that is required.
His email and the photos are self-explanatory, the heads that KC fitted to the engine are substandard (read this as **.
The work that KC did on the heads is poor quality and this has led to further failures. I’m not sure how it is that KC welding up heads on one side of the engine and not supplying port matched heads would be or could be considered a part suppliers problem. This is simply poor workmanship on behalf of KC.
I would like some answers immediately.
Just to remind you of how many times I have emailed you and your responses to date here is a complete outline of all communication on this to date.
DT EMAIL TO KC, My first email to you on this matter was 11/10/14
KC EMAIL TO DT, email You responded and advised me to let you know what parts I needed 11/12/14
DT TO KC, email to Lance I responded acknowledging your request. 11/12/14
DT TO KC, email to Lance Photos of all damaged parts and parts list provided 11/22/14
DT TO KC, email to Lance Requested confirmation of email received 11/22/14
DT TO KC, email to Lance Requested confirmation of email receipt 11/26/14
KC TO DT, email from Lance confirmed receipt of email and forwarded to Keith for his comment 11/27/14. Including photos
DT TO KC, email to Lance acknowledging your email. 11/27/14
DT TO KC, email to Lance and Keith asking for a response 12/11/14
DT TO KC, email to Lance and Keith asking for a response 12/16/14
DT TO KC, email to Lance and Keith asking for a response 12/17/14
DT TO KC, email to Lance and Keith asking for a response 12/23/14
DT TO KC, TELEPHONE CALL spoke to Lance asking for a response 1/7/15 request by yourself to forward photos direct to Keith
DT TO KC, email to Lance confirming telephone conversation 1/7/15 and forwarding photos again
DT TO KC, email to Lance asking for different email address for Keith 1/9/15 because the email address supplied for Keith was incorrect.
KC TO DT, email from Lance saying KC was willing to help 1/10/15
DT TO KC, TELEPHONE CALL to Lance asking what’s going on 1/14/15
DT TO KC, email Keith and Lance forwarding parts list and pictures again as per your request after another telephone call 1/14/15
KC TO DT, email from Lance confirming Keith has been again forwarded all information. 1/14/15 and a copy of an email from Keith to Lance confirming that he wanted photos of all broken parts.
DT TO KC, email to Keith and Lance asking for a time frame on when I will get a response. 1/14/15
DT TO KC, email to Keith with parts list in response to Keith post on Cobra Forum. 2/4/15
KC TO DT, email from Lance confirming that Keith received parts list 2/4/15
DT TO KC, email to Lance confirming his response 2/4/15 and confirming that I have never had a direct response from Keith.
KC TO DT, email from Lance saying he thought I had been in contact with Keith. 2/4/15
DT TO KC, email to Lance stating that Keith has never responded to any emails. 2/5/15
KC TO DT, email from Lance confirming that Keith would have a response tomorrow. 2/5/15
DT TO KC, email to Lance confirming his response 2/5/15.
KC TO DT, email from Lance asking for more information on what happened and how was engine used. 2/7/15
DT TO KC, email to Lance explaining every detail of what occurred with engine. 2/7/15
DT TO KC, email to Lance asking for answers and update on where things were at 2/16/15
KC TO DT, email from Lance stating he would get back to me. 2/17/15
DT TO KC, email to Lance confirming his advice and requesting immediate response. 2/17/15
KC TO DT , email confirming will let me know asap. 2/17/15
DT TO KC, email to Lance asking where we are at 2/19/15
I’ve been more then patient but my patience has run out.
Regards
David Trask
Managing Director
And this is Lances reply
"You would have been more then welcome to come by here while in the US. I would have encouraged it so you could see as many have that we are not a tiny hole in the wall operation with kids building engines. I have spoke with Keith every time I have received emails. I have asked you several times to please email Keith directly. I am stuck in the middle on the deal. All I can do is relay info to him and he has to make the call. I would love to make a call for you but at this time I am not in the position to be able to make these type decisions. The issue with the heads are the core shift in Coons casting s and the reason we no longer use his heads, we now use the Pond. Our cnc machined cuts off the same location every time locating off the head dowel. If it goes thru because of core shift all we can do is weld the heads and pressure test. We do not install without a pressure test off the engine and then inspect on the dyno. I hate that they may have formed a crack after heat cycles on the heads but they would not have been installed if they were leaking here. We have absolutely no desire for any customers to have any issues with our engine. I was able to get Keith to agree to supply front cover and entire timing assembly from Pond as we feel these are the best kits out at this time. Please send an address and I will have the parts drop shipped. Once again I apologize for the issues and wish I could have helped you get answers sooner. Thanks
Lance Smith
Ph 870-246-7460
Fx 870-246-7418
3157 Hwy 26 W
Arkadelphia, AR 71923"
Whilst I appreciate that Lance is making every effort or at least appears to be trying to help out the response from Keith (the company owner) is far from satisfactory as a timing cover and chains are at best about $1,000 worth of parts and not everything required to fix the motor.
How on earth could damage send the engine back?
I mean KC have been negligent in returning calls & emails.
Would you trust them with getting the engine back to you?
Seemingly, Damage was also only just recently in the USA trying to organise a meet, KC dropped the ball on that too.
Lance from KC stated in his email to damage that Keith himself wasn't helping to resolve the situation.
What if YOU WANTED THE BEST OF THE BEST and discovered that the local bloke is better than the famed alternative you bought the engine off.
Would you send it back after being burnt off so many times just for the KC badge?
David Kirkham himself gave you damage's background
He knows elite quality work and didn't see it in his KC engine.
I've resisted the urge to pile on bc it does no one any good, but what if I told you I know of 3 blokes that this has happened to with KC. They fought it then cut their losses and ran.
Granted their engines didn't cost $60k. And whether keith himself built them is debatable. But they were KC Buiilt engines.
How easy is it to play the game of bluff on keith part, asking damage to ship the engine back from the other side of the world. When in actual fact they can't / haven't even supplied the JUST the parts required.
Gentleman damage isn't shooting bambi.
Bambi is seemingly tired, and not helping his cause!
Why are you all so quick to blame the victim here?
I don't think I've read it wrong! But no doubt you all tell me different.
