Old 03-01-2015, 08:08 AM
Blas's Avatar
Blas Blas is offline
Cobra Make, Engine: SPF#0760
Excellent, can you clarify this statement a bit.
"...cut off the right angled adjusting rod, rethread it and attaching a new adjusting handle..." I'm not clear on this as both sides look identical in the photos.
It also looks as if the tie rod between right and left sliders is different (copper color wire)
It appears as the adjuster handle will always be to the right. So the drivers side it to the center of the car and the passengers is to the outside of the car when installed.
Not able to be reconfigured to both be to the inside?
Has anyone ordered both seats adjustable from the factory with both adjusters to the inside of the car?
Thanks so much,
Blas
SPFWiringDiagrams@Comcast.net
