Old 03-02-2015, 10:13 AM
Fitz's Avatar
Fitz Fitz is offline
Cobra Make, Engine: FFR Mk 3 408 530 - 585 T- mustang Dyno at B&R
Things Gone Wrong (Sorted H to L)
Overheating Fan not Working?
Transmission Related Grinds / Vibrates
Brakes Street or Track Use?
Fuel Pump Wrong Type or Size
Alternator Just plain bad?
Carb dialed in Who can help dial in?
Fuel Safe Cell Symptoms - How did you know?
Nut and Bolt Check Always - check twice a year
Radiator Leak Hose connections or rock
Tail Light Covers Plastic Covers Just plain cheap?
Ammeter
Brake Master Cylinder
Charging System Disconnect battery- Trickle Charge
Clutch Related
Front Coil Overs
Gages Smith
Lucas Switches
Master Cylinder
Oil Sending Unit
Speedometer
Starter
Suspension Issue Do we know what to look for?
Throw out Bearing
Tire Wear Rear Heavy foot or alignment
Fitz
fitzus1@gmail.com
