Old 03-03-2015, 01:07 PM
ram_g ram_g is offline
Originally Posted by G-Pete View Post
Ram, county does not matter. You get a TX title issued not a county title. The next step is to register the vehicle.
The registration requirements in some counties are different. BUT, only about emissions - nothing else. If you don't have the custom vehicle brand you are required to have all safety features of the year of your title.
2015 for an example
Active seat belt restrains
Airbags in front
Collapsible steering shaft
DOT shatter windshield double layer
Side impact bars
Back up light
3rd brake light
Side and rear reflectors
Padded steering wheel
...and this is just the begin of the a long list.
G-Pete,
I may have mis-spoken about the difference between title and registration because I applied for all of them together. However the fact remains that the OP could apply for an assembled vehicle title (with no reference to a replica) and then not apply for a Custom Vehicle plate. In that case he would have to follow the standard safety and emissions inspection protocol. For emissions, as I stated, it appears that they are not required at this time where he will be. For safety, I don't know where you got your list, but it is not what is stated on the Texas DPS site. Specifically airbags are not an item of inspection no matter what year your car is, and the list does not vary by model year.
https://www.txdps.state.tx.us/RSD/VI...nCriteria.aspx
05.01 Inspect Every Passenger Car For: (Listed in suggested order of inspection)
* Check for evidence of Financial Responsibility
1. Horn
2. Windshield Wipers
3. Mirror
4. Steering
5. Seat Belts
6. Brakes (system) (Parking - beginning with 1960 models)
7. Tires
8. Wheel Assembly
9. Exhaust System
10. Exhaust Emission System (beginning with 1968 models)
11. Beam Indicator (beginning with 1948 models)
12. Tail Lamps (2); (1) if 1959 model or earlier
13. Stop Lamps (2); (1) if 1959 model or earlier
14. License Plate Lamp (1)
15. Rear Red Reflectors (2)
16. Turn Signal Lamps (beginning with 1960 models)
17. Head Lamps (2)
18. Motor, Serial, or Vehicle Identification Number
19. Gas caps on vehicles 2-24 model years old
20. Window Tint.
Furthermore I once had a Honda Accord where the SRS light came on (due, as it turns out, to a faulty seat belt electrical connector). I was told by my mechanic that it was NOT an item on the annual safety inspection and sure enough I received a sticker even with that fault indicator on.
