Old 03-11-2015, 01:35 PM
kevins2's Avatar
kevins2 kevins2 is offline
Cobra Make, Engine: ERA #795 427 S/C completed Jan. '14 - '68 FE 427 side oiler
Earl,
I'll stop short of saying I'm good at it, but I did manage to get mine aligned. My hinges allow for adjustment in virtually every direction and the issue is when you make an adjustment you can lose track of exactly how much you moved the hinge. I used small pieces of masking tape next to the hinge so I could make small adjustments and know exactly which direction and how much I moved it - and if I moved it too much I could fall back to the previous adjustment rather than starting over. You'll also get good at loosening the bolts just enough to move the hinge but not enough for the hinge to move on its own. I also avoided adjusting the hinge to body and hinge to door alignment at the same time. I used a straight edge across the door/hood/trunk to the body to help get them even. It is deceptive otherwise.
Hopefully, someone will chime in with some better ideas but this is what worked for me.
Kevin
"Anyone who drives faster than you is a maniac and anyone who drives slower than you is an idiot" - George Carlin
