  #394 (permalink)
Old 03-11-2015, 06:20 PM
AUSSIE427SOHC AUSSIE427SOHC is offline
Hi All, Just came across this thread as I am a mad as Fe enthusiast and I am the one that machine's these heads for Paul Munro. I did meet you Dave at the all Ford Day at Willowbank at my friends auto blasting stand with the XA ute. I am glad you like the heads and the machining. They are certainly a lot different than the one's from the Us. I am currently in the process of machining some cam gears for Munro's 0.250" roller chains. I will assist you any way I can as I am sure that you will need it with your rebuild. The above picture is the very first prototype. A you can see, there was a bit of core shift with one of the water holes. We adjust for that by measuring each head individually. Cheers, Warren.
