Old 03-12-2015, 01:36 PM
TNTaylor TNTaylor is offline
Cobra Make, Engine: Kirkham 427 Street, Shelby 468 FE
Originally Posted by Bobcat View Post
Look for an L88 base that was used on Corvettes , Chevelles etc back in the late 60`s . Repops are made today . That base is one of the best flowing bases available .... has just under a 2" drop and will fit a Holley 4150 with a few minor modifications ( cut off the PCV tube , plug it and some minor trimming ) . IMO , much better than the K&N base .
Tried 5 different drop bases on mine and didn`t find any that worked as well as the L88 base . I`m running that with a spun aluminum lid and air director I made with a 3" one layer/pass K&N element .... what they call their racing element . Has very little delta P across it . Those factory guys back in the late 60`s really did know what they were doing .... GM put tons of money making those engines run , take advantage of their research .
Also , do a search on Speedtalk on lids and bases .... there is a ton of info from serious engine builders over there on this subject .
Bobcat - where might I find the L88 base you suggest, as well as spun aluminum lid?
