Originally Posted by Large Arbor
The aluminum tag on the rear is 46/13 which would be 3.54. However I am wondering if it that is correct. I am running 295-50-15's. Any thoughts on what the difference might be?
Thanks for all the comments and advice. This novice appreciates it very much.
Phil
Easy to check. Just jack up the rear so both wheels are off the ground, mark your tire and your drive shaft with some chalk, then rotate your wheel and count the drive shaft rotations.
