Old 03-16-2015, 03:00 PM
Detroit Bill Detroit Bill is offline
Cobra Make, Engine: Superformance, Survival Motorsports aluminum FE 482
Originally Posted by Gaz64 View Post
We need to work out whether the fuel is leaking internally or evaporating (or both).
If you cold start the engine and run for a short period without putting a lot of heat into the engine, then let it sit for 2 days, do the float levels stay correct or drop down as stated?
If they do drop, I'd look at the power valve gaskets and/or the power valve diaphragms for leaks.
If they don't drop, then I'd be looking at adding a phenolic or wood carburettor spacer to help insulate the carb from the engine temperature at hot shutdown.
Wood spacer? I have not heard that before. Wood grows and shrinks with moisture content, that could be a vacuum leak waiting to happen.
Bill
