Old 03-17-2015, 02:02 PM
AKA EDDY's Avatar
AKA EDDY AKA EDDY is offline
Cobra Make, Engine: BDR #648 351w/385hp
Default Replaced brake fluid
I just replaced the brake fluid on my 2008 Backdraft #648. It has 12,500 miles on it and had Dot 5 fluid in it. I replaced it with Dot 3 - 4 fluid. The original fluid was dirty and had some "gel" in it. I found out that when filling the reservoir, if the fluid is a little low, approx. 1 oz, the red warning light comes on. I also discovered that on the dual reservoir, the front chamber is for the rear brakes and the rear chamber is for the front brakes...go figure. Hope this will help someone.
