Thread: FE Engine Oil
Old 03-17-2015, 04:30 PM
RET_COP's Avatar
RET_COP RET_COP is offline
Cobra Make, Engine: Fordstroker 408w custom solid roller-Craft ported Brodix 17*heads-CFM ported Vic Jr. intake-1 3/4 primaries- 575hp-TKO-600RR Liberty upgrade- -Moser 8.8 trutrac-McLeod Street Extreme--QA-1-Wilwood brakes, Classic Chambered 3" Cobrapacks, Avon's
Gibbs is a good product as well as others, you can do a search.
The LIGHTEST oil that works in your engine. Like Dan said clearances are a big factor.
I would like to know why KC recommends 50w oil.
If your engine has good pressure with a lighter oil I would start there.
I have heard hydraulic lifters perform better at high rpm's with a heavier oil (stability) but this may not be your environment.
I've tried 30/40/50. My temps [oil and coolant] were cooler with 30 and pressure was good, so that is what I use.
Try out a few
Lou
