Old 03-17-2015, 07:04 PM
427BDR 427BDR is offline
Originally Posted by Jerry Clayton View Post
we won't learn nothing-I already know-you will learn how muck gas leaks into your engine-you will then determine that its maybe the power valve and replace it-----
got it, I think the ideas are good and the carb probably needs to come off and the PV replaced. But before I do this what if I have a couple of badly fouled spark plugs? could that cause potential flooding on a cold start if 1 or 2 cylinders are not firing because of dirty spark plugs and just pushing gas into the engine?
I'll pull the plugs and change the fouled ones and try a cold restart later this week. If that doesn't improve things then the carb comes off and we attack the PV.
Thanks all, very much appreciate the insights!
