  #56 (permalink)
Old 03-19-2015, 04:13 AM
Nick 427 Nick 427 is offline
Cobra Make, Engine: RCM
I'm still have the same problem as yourself , once I get the brakes a little warm I can get it to shudder at will. My car has a manual transmission and on coast with the clutch pedal in or neutral it will shudder. In gear it does not. I don't believe it's a brake pad or rotor issue as I have changed both. Pads 3 times. My diff ratio is 4.27 LSD and prior to putting these gears in I didn't have any issues. Prior it was 3.31 single wheeler .
I found that when it shudders and I need to stop in a hurry (in traffic) a pull on the handbrake stops it immediately
Can this be a diff issue and not a brake issue ?
