Old 03-20-2015, 09:55 PM
Jac Mac's Avatar
Jac Mac Jac Mac is offline
Cobra Make, Engine: DIY Coupe, F/T ,MkIV.
Originally Posted by Texasdoc View Post
Yes, I offset the edges and applied a small drop of RTV to the ends. I plugged hole Y.
If it were the RMS, wouldn't it show signs of leaking when the oil pump was driven?
No, the oil drainback in the rear main cap is approx. 0.75" x 0.15" so the small amount of oil escaping from rear side of the #5 main bearing which is supplied by a ~0.300" dia gallery is not likely to build up pressure. Very rare, but occasionally I have found that drain hole has not been created due to casting faults.
Gaz 64's comment might have some merit as 351c & 351w share same rear seal dimensions, more likely if flywheel bolts have been over-torqued (85 ft/lb). One possibility in regard to this is if someone has used shorter flexplate bolts with a flywheel, lower number of threads engaged in crank with that combo will result in crank flange deformation or thread damage.
Jac Mac
