Old 03-24-2015, 07:47 AM
trularin's Avatar
trularin trularin is offline
Member of the north
Cobra Make, Engine: A Cobra
If I might add, I had to place a heat shield for my master cylinders. Amazing difference - the headers are basically under them used to heat them to the point I could feel a diffence in pedal. I formed an aluminum shield with a shock absorbing end. Before test I could not grab the MCs after a strong run is 80+ F temps. Now they are air temp cool.
If you are putting in the shields, might want to think about doing this while all the stuff is out of the way.
Hope this helps.
Tru
