Old 03-30-2015, 10:17 AM
DAVID GAGNARD's Avatar
Originally Posted by Wisconsin_Snake View Post
I was told (can't remember from either a complete stop or maybe it was where the car was just rolling) to put it in third and steep on the gas... If the engine really bogged down, that was good, if the engine did not (Rpm's increased) your clutch was slipping.
yes,get going about 30mph and then shift to 4th gear and stand on the gas,if the clutch is slipping engine rpms will go off the tach,if it just tries to pull itself and go or bog down some,then the clutch is NOT slipping....
Once it slips in high gear,you'll know it and smell it if you let it slip long enough,which I don't recommend.....
David
DAVID GAGNARD
