Old 04-01-2015, 04:12 PM
rsk289's Avatar
rsk289 rsk289 is offline
Cobra Make, Engine: 289 leafspring, r/p
Default Resurrecting this old thread...
I now have my nice new T10L correct ally-casing trans from Jim Cowles sitting next to the toploader. The tail casings are different. The reason I was having trouble getting the trans to sit correctly is that the mounting pad on the T10 sits around 3/4" lower from the output shaft centre than the toploader's mounting pad. I am using the correct-for-Cobra T'bird style chassis trans mount, as supplied by Acton, which works perfectly with the T10 but which would need a substantial spacer to mount the toploader at the correct height. Also, as a minor issue, the T10 mounting pad threaded holes are closer together, to suit the T'bird type clamping bracket.
Mystery solved - the T10 and toploader mounting pad positions are different!
This T10 is a real work of art...
Roger
