Thread: 427 dart block
Old 04-02-2015, 06:45 AM
DJPlaster58 DJPlaster58 is offline
Cobra Make, Engine: Backdraft
I had my engine out recently and found the left mount (driver side) interfered on the inside with the block keeping the mount from being securely fixed to the block. It was hanging up on one for the block plugs on the Dart Block. Someone attempted to grind it but they did not take enough material off the mount. I milled out a section of the inside of the mount so there is visible clearance. The mount now is fastened as should be on the block. I believe this could contribute to losing bolts or the appearance the bolts aren't tight.
