I finished the front suspension in January actually. Including the charcoal canister (that fits between the suspension arms on the left, and the horns that fit on the right).
Then all the brake, clutch, fuel and charcoal vapour hard lines were fitted.
Handbrake. Passenger side. I modified this from standard just to lower it a little so the cable pulled straighter. Would really matter,I'm told, but I preferred that to a broken wire and a jammed handbrake later on!
Then the rear suspension and axles. All a bit tricky. I'm learning new sh!t daily!
