04-05-2015, 02:02 PM
AR
Hey Bob - if you are out there - just re-read this in your post back on page 1.
"Did I ever send you a new wire module from the under-dash module to the main harness?"
Is there something I need to replace?
Jerry - I did a lot of trouble-shooting back on posts 1 - 10. I stood outside the car and replaced 3 fuses in a row - each of which blew as soon as I hit the left turn signal. I wasn't even inside the car so stepping on the brake didn't have anything to do with the problem. I isolated it down to the turn signal or dimmer relay and since it blew fuses with headlights off - that seemed to point to the turn signal switch itself. And then it cured itself until a drive I took the other day.
Patrick - possibly a good point. I doubt ERA is spending $250 for OEM switches which means this one was undoubtedly a repro.
